1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: MVME6100 or 7100
To: Matt Rippa <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 03 Nov 2008 10:51:35 -0800
Matt Rippa wrote:
Hi Kate, Till -
I'm just starting up a campaign here at Gemini to research RTEMS for out telescopes. I now have a 6100 board which I'll be using. Are there any links to the 6100 BSP's you've developed?
Are there any active efforts I may be able to assist with in this area? A solid part of my time may be allocated to this in 2009.
Is it true all EPICS/RTEMS bsp's are latched to version 4.6?
No. We currently use RTEMS 4.7.1 in production and 4.9.0 / EPICS 3.14.10
for development (planning to upgrade our production systems when we have a chance).
The mvme6100 is our standard platform for LCLS but we also use some mvme3100s
The mvme3100 BSP is bundled with RTEMS 4.9 but the BSP for the 6100 is not
(yet).
HTH
--Till
Thanks for any info, -Matt
Till Straumann wrote:
LCLS (SLAC) uses the MVME6100 albeit with RTEMS not vxWorks.
Experience has been good.
-- Till
Matt Rippa wrote:
Hi All -
Are any sites using the MVME6100 on VxWorks 5.5.2/Tornado 2.2.1? If so, would you recommend these?
Has anyone considered the new MVME7100 board? I'm not sure on the state of the BSP.
-Matt
Prev: RE: MVME6100 or 7100 Erik Johansson
Next: Job opening Liyu, Andrei V
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EDM cursors GOURNAY Jean-Francois
