1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: base-3.14.10: libcurses vs. libncurses
To: [email protected]
Date: Tue, 04 Nov 2008 14:22:21 +0100
Hi all,
I have once again a (stupid/nasty?) question concerning the usage of libcurses vs. libncurses
In configure/os/CONFIG.Common.linuxCommon of base-3.14.10 we see the line:
LDLIBS_READLINE = -lreadline -lcurses
Knowing that I could redefine it with an additional, local, site-specific CONFIG.... file
I still have the basic question why it is still "old" curses library libcurses, given the fact (AFAIK) nowadays (new=n) libncurses is used.
(q.v. Wikipedia: http://en.wikipedia.org/w/index.php?title=Curses_(programming_library)&oldid=242733108 : "While development of ncurses <http://en.wikipedia.org/wiki/Ncurses> and *PDCurses* continues, UNIX <http://en.wikipedia.org/wiki/UNIX> curses development appears to have halted in the mid-1990s when X/Open Curses was defined"
Couldn't this line be changed to libncurses, are there any reasons against it?
(BTW: Typically libcurses is pointing in many systems by a symbolic link to libncurses)
Just for completeness
(I already solved it by changing the above line, or putting a link, or creating an additional CONFIG file):
I am using an unmodified OpenSuse 10.2 installation
and received during make of base, the following error
make -C ./libCom install
make[2]: Entering directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom/O.linux-x86'
/usr/bin/g++ -o libCom.so.3.14 -shared -fPIC -m32 bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.oellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o e!
picsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o -lpthread -lreadline -lcurses -lm -lrt -lgcc
/usr/lib/gcc/i586-suse-linux/4.1.2/../../../../i586-suse-linux/bin/ld: cannot find -lcurses
collect2: ld returned 1 exit status
make[3]: *** [libCom.so.3.14] Error 1
make[3]: Leaving directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom/O.linux-x86'
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `<HOME>/EPICS-3.14.10/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `<HOME>/EPICS-3.14.10/base-3.14.10/src'
make: *** [src.install] Error 2
Best regards, Peter
Dr. rer. nat. Peter W. Zumbruch
EE - department / Controls group / GSI
E-Mail: P.Zumbruch_at_gsi.de
Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
Gesellschaft für Schwerionenforschung mbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführer: Professor Dr. Horst Stöcker
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Re: base-3.14.10: libcurses vs. libncurses Andrew Johnson
Prev: Re: GPIB - asyn - streamdevice Dirk Zimoch
Next: IOC to use time from its own processor Dehong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Job opening Liyu, Andrei V
Next: Re: base-3.14.10: libcurses vs. libncurses Andrew Johnson
