Subject: |
Re: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded |
Andrew Johnson <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 10 Nov 2008 13:15:56 -0600 |
Hi Peter,
On Monday 10 November 2008 11:49:55 Peter Zumbruch wrote:
> I am facing the following problem.
> I try to compile msi 1.4 using base 3.14.10.
> I get the following crash.
> Any idea?
> Hints would be appreciated.
> Compiling the same code against 3.14.9 succeeds.
We need to release a new version of MSI; this problem is already fixed in the
CVS repository, but hasn't been made into new a release yet, for which I
apologize. If you're reading this on Tuesday look for a new version 1.5
which I'll try to get out this afternoon, but if you need it sooner you can
get the latest CVS snapshot from the download/extensions page which should
build against 3.14.10 immediately.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Peter Zumbruch
Re: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded J. Lewis Muir
<2008>
2025
2026
<2008>
2025
2026
