1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded
To: EPICS tech-talk <[email protected]>
Date: Mon, 10 Nov 2008 18:49:55 +0100
I am facing the following problem.
I try to compile msi 1.4 using base 3.14.10.
I get the following crash.
make -C ./msi1_4 install
make[1]: Entering directory `<EPICS Extension Dir>/src/msi1_4'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[2]: Entering directory `<EPICS Extension Dir>/src/msi1_4/O.linux-x86'
/usr/bin/gcc-3.4 -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500 -D_X86_ -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi   -O3   -Wall      -m32     -g  -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I../../../../base-3.14.10/include/os/Linux -I../../../../base-3.14.10/include  -I../../../include          ../msi.c
../msi.c: In function `main':
../msi.c:69: error: `TRUE' undeclared (first use in this function)
../msi.c:69: error: (Each undeclared identifier is reported only once
../msi.c:69: error: for each function it appears in.)
../msi.c:86: error: `FALSE' undeclared (first use in this function)
../msi.c: In function `makeSubstitutions':
../msi.c:167: error: `TRUE' undeclared (first use in this function)
../msi.c:225: error: `FALSE' undeclared (first use in this function)
../msi.c: In function `inputAddPath':
../msi.c:298: error: `TRUE' undeclared (first use in this function)
../msi.c:298: error: `FALSE' undeclared (first use in this function)
../msi.c: In function `freePattern':
../msi.c:506: error: `FALSE' undeclared (first use in this function)
../msi.c: In function `substituteGetNextSet':
../msi.c:551: error: `FALSE' undeclared (first use in this function)
../msi.c:553: error: `TRUE' undeclared (first use in this function)
../msi.c: In function `substituteGetReplacements':
../msi.c:616: error: `FALSE' undeclared (first use in this function)
../msi.c:630: error: `TRUE' undeclared (first use in this function)
../msi.c: At top level:
../msi.c:487: warning: 'freeSubFile' defined but not used
make[2]: *** [msi.o] Error 1
make[2]: Leaving directory `<EPICS Extension Dir>/src/msi1_4/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `<EPICS Extension Dir>/src/msi1_4'
make: *** [msi1_4.install] Error 2
My system is a debian sarge (3.1) clone using gcc3.4 and gmake 3.81.
Any idea?
Hints would be appreciated.
Compiling the same code against 3.14.9 succeeds.
Best regards,
Peter
Dr. rer. nat. Peter W. Zumbruch
EE - department / Controls group / GSI
E-Mail: P.Zumbruch_at_gsi.de
Tel: +49-(6159)-71-1435 / Fax: +49-(6159)-71-2986
GSI Helmholtzzentrum für Schwerionenforschung GmbH
Planckstraße 1 / D-64291 Darmstadt / www.gsi.de
Gesellschaft mit beschränkter Haftung
Sitz der Gesellschaft: Darmstadt
Handelsregister: Amtsgericht Darmstadt, HRB 1528
Geschäftsführung: Professor Dr. Horst Stöcker, Christiane Neumann
Vorsitzende des Aufsichtsrates: Dr. Beatrix Vierkorn-Rudolph,
Stellvertreter: Ministerialdirigent Dr. Rolf Bernhardt
Re: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Andrew Johnson
Re: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded J. Lewis Muir
Prev: RE: question about ca gateway Jeff Hill
Next: Re: msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Re: question about ca gateway, 万天敏
