Hello,Dirk Zimoch
Do as you said, I set the EPICS_CA_ADDR_LIST and EPICS_CA_SERVER_PORT to the gateway's sip and sport on client ,the client can get the pv even in situation of gateway display error messages. Thanks for your help, by means of this; the user can get the pv when some ioc is configured incorrectly.
Best Regards
wantianmin
- Re: Re: question about ca gateway 万天敏
- Re: question about ca gateway Dirk Zimoch
Re: WireSet missing with 3.14.10 Andrew Johnson
USE of CA lib: problem using ca_array_put_callback with strings haquin
<2008>
2025
2026
msi1_4 build - compile against base 3.14.10 crashes - `TRUE' undefinded Peter Zumbruch
<2008>
2025
2026
