Hi Dehong,
On Thursday 13 November 2008 15:11:02 Dehong Zhang wrote:
> We need the "vxWorks6-mv5100" architecture, but the base package does not
> have it.
Ah, that's the problem, no you don't; the vxWorks6 targets have been merged
back into the regular vxWorks ones (they should never have been added to
3.14.8 in the first place). Use the supplied vxWorks-ppc604_long or
vxWorks-ppc604_altivec targets instead; if your MVME5100 board has an MPC750
CPU use vxWorks-ppc604_long, but if your board is really an MVME5110 and has
a MPC7410 CPU with altivec enabled then use vxWorks-ppc604_altivec instead.
I suggest you:
1. Delete all the vxWorks6 files you created under base/configure/os
2. Edit base/configure/os/CONFIG_SITE.Common.vxWorksCommon and define the
WIND_BASE setting in there to point to your vxWorks 6 installation
3. Edit base/configure/CONFIG_SITE and change CROSS_COMPILER_TARGET_ARCHS to
use the appropriate target(s) as described above
4. In the base top level directory, run 'make distclean; make'
5. Repeat step 4 for all your support modules
6. In your IOC area, edit the iocBoot/ioc*/Makefile and change the setting for
ARCH to the correct architecture as discussed above, then 'make distclean;
make' in the application top level directory and try booting the IOC.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: WireSet missing with 3.14.10 Dehong Zhang
- WireSet missing with 3.14.10 Dehong Zhang
- Re: WireSet missing with 3.14.10 Andrew Johnson
Re: Re: question about ca gateway, 万天敏
<2008>
2025
2026
<2008>
2025
2026
