Hi, Dirk zimoch
just as you said, I start the ca gateway like this:
#!/bin/bash
export EPICS_CA_ADDR_LIST="10.30.1.165:5064 10.30.1.166:5066 ..."(set the environment variable)
export EPICS_CA_AUTO_ADDR_LIST=NO
gateway -sip 10.30.50.1 -sport 6006 -pvlist /root/GATEWAY.pvlist -access /root/private01.access -log logfile.txt
with -sip 10.30.50.1 and -sport 6006 option, so the user set the EPICS_CA_ADDR_LIST="10.30.50.1:6006",and they didn't set the EPICS_CAS_BEACON_LIST, so if they start an ioc,the ioc will send the udp package to the gateway's port which cause the question occurs.(they use base 3.14.9 to compile ioc) ,you mean if I compiled the ca gateway use base 3.14.10 the question will not occurs? I will try it immediately .
Thank for you help,
Best Regards.
wantianmin
- Re: question about ca gateway Dirk Zimoch
Re: WireSet missing with 3.14.10 Andrew Johnson
<2008>
2025
2026
<2008>
2025
2026
