Hello wantianin,
Do you set EPICS_CA_ADDR_LIST to something including a port number?
The portable channel access server (and thus the gateway) is quite sensitive
unexpected messages on its channel search UDP port, for example beacons.
Unfortunately, using port numbers in EPICS_CA_ADDR_LIST is used as a default for
EPICS_CAS_BEACON_ADDR_LIST using the same ports. This lets the IOC send beacons
on the UDP port where search requests are expected by the gateway.
With 3.14.10, the gateway should not crash any more.
Dirk
万天敏 wrote:
> hi all,
> I have meet a strange question about ca gateway, in our situation, ca gateway is running on a workstation , a softioc (use makeBaseApp.pl to create ) is running on a machine in the same subnet, the ca gateway will display the following error message and then the corresponding pv can not be get from the ca gateway. it seems that the ioc send some udp package to the ca gateway which cause the error occurs. when this ioc is running, the error will occurs continually, if restart the ca gateway ,we can get pv for a few seconds and then fails again. before start the ioc, if we set the environment variable "EPICS_CAS_INTF_ADDR_LIST=127.0.0.1" or set some other environment variable to let the ioc not to send message to ca gateway ,the error will not occur,
> Is there some way of solve this problem? ps: I notice that only when the ioc is complied use base3.14.9(if recompile the ca gateway in base 3.14.9 the problem still occurs),and if the ioc is compiled use 3.14.8.2 the problem will not occur.
> error message:
> CAS: CAS Request: ? on 10.30.50.13:32920: cmd=13 cid=11 typ=11 cnt=5080 psz=0 avail=a1e320d
> Nov 03 10:00:00 !!! Errlog message received (message is above)
> bad request code=13 in DG
> filename="../../../../src/cas/generic/st/casDGIntfOS.cc" line number=498
> protocol from client was invalid unexpected problem with UDP input from "10.30.50.13:32920"
> Nov 03 10:00:01 !!! Errlog message received (message is above)
> thanks a lot,
> wantianin
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- question about ca gateway 万天敏
RE: Fast Cross-IOC Loops? Thompson, David H.
Re: Fast Cross-IOC Loops? Dirk Zimoch
<2008>
2025
2026
RE: question about ca gateway Jeff Hill
Re: Re: question about ca gateway 万天敏
<2008>
2025
2026
