1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fast Cross-IOC Loops?
To: Ralph Lange <[email protected]>
Date: Wed, 12 Nov 2008 17:16:56 +0100
Hi Ralph
Answer one: Don't do that.
Answer two: We are working on a solution to use the data buffer of the timing system for real-time communication. We will need such a fast channel for our FEL. At the moment, the data flow is only one way. We hope that "upstream" communication will be possible soon (depending how busy Jukka is).
Dirk
Ralph Lange wrote:
Hello!
What would be the smartest way to implement fast cross-IOC loops that are high-priority?
Problem: The CA server tasks on the target IOC are low priority (for good reasons, I know!), so that - even with a fast synchronous device support -
any stupid slow-and-low record processing on that IOC will introduce delays, which leads to jitter or multiple CA updates before the target record gets processed.
Oh, yes: "fast" would be something below 200Hz.
Any hints welcome...
Ralph
-- Dr. Dirk Zimoch Paul Scherrer Institut, WBGB/006 5232 Villigen PSI, Switzerland Phone +41 56 310 5182
Re: Fast Cross-IOC Loops? Jukka Pietarinen
Fast Cross-IOC Loops? Ralph Lange
Prev: Re: question about ca gateway Dirk Zimoch
Next: Re: Fast Cross-IOC Loops? Matthieu Bec
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Fast Cross-IOC Loops? Thompson, David H.
Next: Re: Fast Cross-IOC Loops? Jukka Pietarinen
