1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fast Cross-IOC Loops?
To: Ralph Lange <[email protected]>
Date: Wed, 12 Nov 2008 14:33:00 -0300
We use reflective memory (GeFanuc) to convey fast information between remotely separate systems. The nodes come in different h/w flavor (PCI, VME,...) linked by fiber. Our nominal rate is 200Hz.
I don't know if thats the cross-IOC solution you are looking - if you think a big pool of memory that can shared between remote processes, that as wake-up/broadcast capabilities, that might be an option. It's been good for us!
Matthieu
Ralph Lange wrote:
Hello!
What would be the smartest way to implement fast cross-IOC loops that are high-priority?
Problem: The CA server tasks on the target IOC are low priority (for good reasons, I know!), so that - even with a fast synchronous device support -
any stupid slow-and-low record processing on that IOC will introduce delays, which leads to jitter or multiple CA updates before the target record gets processed.
Oh, yes: "fast" would be something below 200Hz.
Any hints welcome...
Ralph
Matthieu Bec              Gemini Observatory
Tel: +56 51 205785        c/o AURA, Casilla 603
Fax: +56 51 205650        La Serena, Chile
Fast Cross-IOC Loops? Ralph Lange
Prev: Re: Fast Cross-IOC Loops? Dirk Zimoch
Next: WireSet missing with 3.14.10 Dehong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fast Cross-IOC Loops? Jukka Pietarinen
Next: RE: Fast Cross-IOC Loops? Thompson, David H.
