1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fast Cross-IOC Loops?
To: Ralph Lange <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Thu, 20 Nov 2008 12:00:12 -0500
One other option is a VME bus extender.  That way you may not even need
a processor on the other end.  In my other life we ran a manipulator off
of a bridge crane over fiber that way.
I am using a set of the Fanuc shared memory modules in our timing system
to get field data to our RTDL.  Nice part of it being in the timing
system is that it does not need to do any hand shaking, just checking,
since I know when everything happens.  The delay from point A to B is
just a few microseconds, insignificant in our case.
-----Original Message-----
[mailto:[email protected]] On Behalf Of Ralph Lange
Sent: Wednesday, November 12, 2008 9:20 AM
To: EPICS Tech Talk
Subject: Fast Cross-IOC Loops?
Hello!
What would be the smartest way to implement fast cross-IOC loops that
are high-priority?
Problem: The CA server tasks on the target IOC are low priority (for
good reasons, I know!), so that - even with a fast synchronous device
support -
any stupid slow-and-low record processing on that IOC will introduce
delays, which leads to jitter or multiple CA updates before the target
record gets processed.
Oh, yes: "fast" would be something below 200Hz.
Any hints welcome...
Ralph
Fast Cross-IOC Loops? Ralph Lange
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fast Cross-IOC Loops? Matthieu Bec
Next: WireSet missing with 3.14.10 Dehong Zhang
