1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USE of CA lib: problem using ca_array_put_callback with strings
Cc: [email protected]
Date: Thu, 20 Nov 2008 17:49:18 +0100
Hi Andew,
We are in the following config:
- vxWorks 6.5
- MPC 7457 processor
- MVME5500 -0161
- BSP version 2.0/4
The epics target is vxWorks-mvme5500
I didn't modified the source code of the R3.14.9,
I still have to check it has not been modified by someone else,
I keep you informed about this point.
Regards.
Andrew Johnson a Ãcrit :
Hi Christophe,
On Monday 17 November 2008 02:58:09 haquin wrote:
We've just realized that my IOC was running under VxWorks !
So I restarted the SAME IOC but under linux-x86 and then all is working
correctly.
Here is the difference you are looking for, the problem occur under
VxWorks.
I've just tried this with a couple of vxWorks IOCs (both vxWorks-ppc604_long and vxWorks-68040) on both R3.14.9 and R3.14.10 and I don't see the bug occurring:
tux% caput -c anj:aiExample.DESC "New string"
Old : anj:aiExample.DESC             Analog input
New : anj:aiExample.DESC             New string
tux% caput -c -s -a anj:aiExample.DESC 1 "Array string"
Old : anj:aiExample.DESC             New string
New : anj:aiExample.DESC             Array string
tux% caput -c -s -a anj:aiExample.DESC 2 Array string
Old : anj:aiExample.DESC             Array string
Write callback operation timed out
What version of vxWorks are you running, on what CPU, and what epics target architecture are you using for the IOC? Have you made any modifications to the R3.14.9 source code at all?
- Andrew
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
USE of CA lib: problem using ca_array_put_callback with strings haquin
Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Prev: Re: A db question about aiExample Ned Arnold
Next: RE: Fast Cross-IOC Loops? Thompson, David H.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
