1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USE of CA lib: problem using ca_array_put_callback with strings
Cc: [email protected]
Date: Mon, 17 Nov 2008 09:58:09 +0100
Hi Andrew,
Of course, the test with the caput tells us that the problem is not in the example client program.
We've just realized that my IOC was running under VxWorks !
So I restarted the SAME IOC but under linux-x86 and then all is working correctly.
Here is the difference you are looking for, the problem occur under VxWorks.
If you are still interrested to know more about my IOC, Here is more about it:
we have a Waveform record using ASYN/MODBUS device support,
Some "GenSub", "ai" and "ao" records all using soft device support
=> the problem occur independently of the record type (under VxWorks only)
Regards.
Andrew Johnson a Ãcrit :
Hi Christophe,
On Friday 14 November 2008 10:34:16 haquin wrote:
We tried with the command line, and we can reproduce the problem, here
is the result:
[haquin@accep1 haquin]$ caput -c LB-DIA-ALB-TST2:Read_16bits_Reg.DESC
"abcdefg"
Old : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC It's 14-NOV-2008 16:52:23.04
New : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC a
[haquin@accep1 haquin]$ caput LB-DIA-ALB-TST2:Read_16bits_Reg.DESC
"abcdefg" Old : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC a
New : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC abcdefg
That is very interesting, and tells me that the problem is probably not in that example client program.
Tell me about the IOC that this PV resides on, and the record type and device support of the record itself. Does the problem also occur with other fields or other record types? Is it limited to this particular IOC, or this architecture of IOC?
I'm trying to find out what might be different about your installation and IOC, because I am unable to replicate this behavior on a linux-x86 IOC here using R3.14.9.
- Andrew
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
USE of CA lib: problem using ca_array_put_callback with strings haquin
Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Prev: SNL compiler bug (and a fix) Benjamin Franksen
Next: How to creat 'target' IOC running on a Linux PC zhangdemin99
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
