1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USE of CA lib: problem using ca_array_put_callback with strings
To: [email protected]
Date: Fri, 14 Nov 2008 10:04:49 -0600
Hi Christophe,
On Friday 14 November 2008 08:01:43 haquin wrote:
> I have some problems with the Channel Access library use,
> more precisely the use of /*ca_array_put_callback*/ with STRINGS !
> We are using a peace of exemple C code, picked-up at :
> *http://lansce.lanl.gov/EPICSdata/ca/client*, that uses this CA API.
> We have some problems with the ca_array_put_callback when we want to
> write strings.
That URL doesn't work any more, can you post at least an extract of the code
that you're using, showing both the call to ca_array_put_callback() and your
callback routine.
> We use this code to put a string in the DESC field of a record,
> The problem is that only the first caracter of the string is written to
> the PV,
> The callback is called, everything seem to bee correct except that there
> is only the first caracter in the destination.
I'm not able to recreate the problem on R3.14.10, so it may be a bug in the
code you're using (I'm not suggesting that you need to upgrade though, since
I'm not aware of any bug fixes in that area of the code).  The caput program
that comes with base has a -c option that means 'use put callback' and can
deal with arrays.  Here's how I tested it:
tux% bin/linux-x86_64/caput -c anjHost:aiExample.DESC "New string"
Old : anjHost:aiExample.DESC         Analog input
New : anjHost:aiExample.DESC         New string
tux% bin/linux-x86_64/caput -c -s -a anjHost:aiExample.DESC 1 "Array string"
Old : anjHost:aiExample.DESC         New string
New : anjHost:aiExample.DESC         Array string
Note that the DESC field will only accept a 1-item array; if you try to send
more it will fail, demonstrating that caput is doing an array put:
tux% bin/linux-x86_64/caput -c -s -a anjHost:aiExample.DESC 2 String array
Old : anjHost:aiExample.DESC         Array string
Write callback operation timed out
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Prev: USE of CA lib: problem using ca_array_put_callback with strings haquin
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
