1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USE of CA lib: problem using ca_array_put_callback with strings
Cc: [email protected]
Date: Fri, 28 Nov 2008 14:54:40 +0100
Hi Andrew,
Did you find time to have a look to my configuration ?
Actually, I am not the one who is in charge of the EPICS release we use on my project,
but the one who is responsible for this made a test with the 3.14.10 release and it turns out that everything works fine with this it.
So our problem really seems to be in the 3.14.9 release,
Before considering switching to 3.14.10 release we woould like to know if there is a chance to solve this on 3.14.9.
Best Regards.
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
USE of CA lib: problem using ca_array_put_callback with strings haquin
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Prev: NTP-Time on RTEMS(vxWorks) Problem Jens Eden
Next: Re:RE: Use of waveform records marco_hair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Next: SNL compiler bug (and a fix) Benjamin Franksen
