Hi Andrew,
We made the test with the target "vxWorks-ppc604_long", and the problem
remains.
So as you requested, you will find attached an archive of our configuration.
Which VxWorks version are you running ?
Hope this will help.
Regards.
Andrew Johnson a Ãcrit :
Hi Christophe,
On Thursday 20 November 2008 10:49:18 haquin wrote:
We are in the following config:
- vxWorks 6.5
- MPC 7457 processor
- MVME5500 -0161
- BSP version 2.0/4
The epics target is vxWorks-mvme5500
I didn't modified the source code of the R3.14.9,
I still have to check it has not been modified by someone else,
I keep you informed about this point.
The vxWorks-mvme5500 target architecture is not one that ships with EPICS
Base. Can you try building and using the vxWorks-ppc604_long architecture
instead (which is the official target for that processor) and see if the
problem still occurs? If not, you'll have to post the configuration files
you're using for that target (base/configure/os/*vxWorks-mvme5500*) for me to
help any further.
- Andrew
configure.zip
Description: Zip compressed data
begin:vcard
fn:Christophe Haquin
n:Haquin;Christophe
email;internet:[email protected]
tel;work:02 31 45 46 61
x-mozilla-html:FALSE
version:2.1
end:vcard
- USE of CA lib: problem using ca_array_put_callback with strings haquin
- Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
- Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
CSS 1.1.0 Hatje, Jan
Problem with libCom/osi/os/WIN32/osdTime.cpp in 3.14.10 Mark Rivers
<2008>
2025
2026
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
