1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USE of CA lib: problem using ca_array_put_callback with strings
To: haquin <[email protected]>
Cc: [email protected]
Date: Thu, 20 Nov 2008 11:16:38 -0600
Hi Christophe,
On Thursday 20 November 2008 10:49:18 haquin wrote:
> We are in the following config:
> - vxWorks 6.5
> - MPC 7457 processor
> - MVME5500 -0161
> - BSP version 2.0/4
> The epics target is vxWorks-mvme5500
> I didn't modified the source code of the R3.14.9,
> I still have to check it has not been modified by someone else,
> I keep you informed about this point.
The vxWorks-mvme5500 target architecture is not one that ships with EPICS
Base.  Can you try building and using the vxWorks-ppc604_long architecture
instead (which is the official target for that processor) and see if the
problem still occurs?  If not, you'll have to post the configuration files
you're using for that target (base/configure/os/*vxWorks-mvme5500*) for me to
help any further.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Prev: RE: Fast Cross-IOC Loops? Thompson, David H.
Next: Re: CAEN V965 driver Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
