Folks,
I've found a bug in osdTime.cpp for win32-x86 in 3.14.10. The problem
is a race condition at initialization that can cause the IOC to crash as
soon as it starts.
Andrew Johnson solved it with the following patch, but since he is gone
for a while I thought I would send this fix out in case others are
having the same problem.
Cheers,
Index: osdTime.cpp
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/libCom/osi/os/WIN32/osdTime
.cpp,v
retrieving revision 1.38.2.7
diff -u -r1.38.2.7 osdTime.cpp
--- osdTime.cpp 26 Aug 2008 20:31:09 -0000 1.38.2.7
+++ osdTime.cpp 24 Nov 2008 22:53:47 -0000
@@ -85,7 +85,7 @@
epicsTimerNotify::expireStatus expire ( const epicsTime & );
-static currentTime * pCurrentTime = 0;
+static volatile currentTime * pCurrentTime = 0;
static const LONGLONG FILE_TIME_TICKS_PER_SEC = 10000000;
static const LONGLONG EPICS_TIME_TICKS_PER_SEC = 1000000000;
static const LONGLONG ET_TICKS_PER_FT_TICK =
@@ -96,12 +96,13 @@
static int timeRegister(void)
- pCurrentTime = new currentTime ();
/* Must register with generalTime here since the epicsTimer
* in the PLL ends up calling epicsTime::getCurrent()
generalTimeCurrentTpRegister("PerfCounter", 150,
osdTimeGetCurrent);
- pCurrentTime->startPLL ();
+ pCurrentTime = (volatile currentTime *)new currentTime ();
+ ((currentTime *)pCurrentTime)->startPLL ();
return 1;
static int done = timeRegister();
@@ -111,11 +112,11 @@
static int osdTimeGetCurrent ( epicsTimeStamp *pDest )
- if ( ! pCurrentTime ) {
- return epicsTimeERROR;
+ while ( ! pCurrentTime ) {
+ Sleep(1);
- pCurrentTime->getCurrentTime ( *pDest );
+ ((currentTime *)pCurrentTime)->getCurrentTime ( *pDest );
return epicsTimeOK;
Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
areaDetector R1-3 released Mark Rivers
<2008>
2025
2026
CSS 1.1.0 Hatje, Jan
<2008>
2025
2026
