1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: USE of CA lib: problem using ca_array_put_callback with strings
To: haquin <[email protected]>
Cc: [email protected]
Date: Fri, 14 Nov 2008 11:37:31 -0600
Hi Christophe,
On Friday 14 November 2008 10:34:16 haquin wrote:
> We tried with the command line, and we can reproduce the problem, here
> is the result:
> [haquin@accep1 haquin]$ caput -c LB-DIA-ALB-TST2:Read_16bits_Reg.DESC
> "abcdefg"
> Old : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC It's 14-NOV-2008 16:52:23.04
> New : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC a
> [haquin@accep1 haquin]$ caput LB-DIA-ALB-TST2:Read_16bits_Reg.DESC
> "abcdefg" Old : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC a
> New : LB-DIA-ALB-TST2:Read_16bits_Reg.DESC abcdefg
That is very interesting, and tells me that the problem is probably not in
that example client program.
Tell me about the IOC that this PV resides on, and the record type and device
support of the record itself.  Does the problem also occur with other fields
or other record types?  Is it limited to this particular IOC, or this
architecture of IOC?
I'm trying to find out what might be different about your installation and
IOC, because I am unable to replicate this behavior on a linux-x86 IOC here
using R3.14.9.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Re: USE of CA lib: problem using ca_array_put_callback with strings Andrew Johnson
Prev: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
Next: Re: WireSet missing with 3.14.10 Dehong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: USE of CA lib: problem using ca_array_put_callback with strings haquin
