1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: WireSet missing with 3.14.10
Cc: [email protected]
Date: Fri, 14 Nov 2008 17:15:33 -0600
Hi Andrew,
Thank you so much!  It is working.
Now I need to re-build my CaChannel stuff.  That is for next week.
Best regards,
Dehong
----- Original Message -----
Date: Friday, November 14, 2008 2:13 pm
To: Dehong Zhang <[email protected]>
> Hi Dehong,
> On Friday 14 November 2008 12:28:23 Dehong Zhang wrote:
> > Our board actually has MPC7455 processor, with AltiVec coprocessor.
> > I followed your suggestions and tried vxWorks-ppc604_altivec.  Still
> > got the same error messages:
> Ok, now your installation is using all the standard build rules so I
> believe
> that the problem is mine and not yours.  Thanks for posting the IOC
> console
> log, that also helps a lot.
> > # Epics Startup command file
> > # cd "/home/vxworks_boot/fe/hinst1/epics"
> > # putenv("EPICS_TS_NTP_INET='127.0.0.1'")
> > putenv("EPICS_CA_MAX_ARRAY_BYTES=1048576")
> > value = 0 = 0x0
> > ld < hinst1.munch
> > Warning: module 0x329d640 holds reference to undefined symbol
> > _Z7WireSetIfEvRKT_Ph.
> _Z7WireSetIiEvRKT_Ph.
> _Z7WireSetIsEvRKT_Ph.
> I tried various versions of c++filt for gcc 3.x, and finally found
> that the
> version for my linux system (which actually has gcc 4.1.2) can
> translate
> those symbols, as long as I strip off the trailing '.', giving this:
>     void WireSet<float>(float const&, unsigned char*)
>     void WireSet<int>(int const&, unsigned char*)
>     void WireSet<short>(short const&, unsigned char*)
> Those functions should be being in-lined by the compiler wherever they
> are
> used (they are on my systems), so I don't understand why you're
> getting this
> error.  It may just be an issue with the vxWorks 6.1 compiler though —
> if
> there are any other vxWorks 6.x users reading, do you see this problem?
> However it is easy to explicitly instantiate the functions manually.
> Apply
> the attached patch file to your base/src/ca/templateInstances.cpp file
> and
> run 'make' first at the top of base and then in your IOC application top.
> I think that should solve the problem; please let me know if it does
> so I can
> commit that change for the next release of Base.
> - Andrew
> Talk is cheap. Show me the code. -- Linus Torvalds
WireSet missing with 3.14.10 Dehong Zhang
Re: WireSet missing with 3.14.10 Andrew Johnson
Re: WireSet missing with 3.14.10 Dehong Zhang
Prev: Re: WireSet missing with 3.14.10 Andrew Johnson
Next: SNL compiler bug (and a fix) Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: USE of CA lib: problem using ca_array_put_callback with strings haquin
