1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Working with sequencer
To: tech-talk <[email protected]>
Date: Thu, 20 Nov 2008 15:04:20 -0600
I've run into a little 'problem' I haven't been able to figure out yet.
I'm building an IOC that will have a sequencer program in it.
I've been trying to get the *.stt program to compile automatically as a part of the build.
Problem is that I'm unclear as to how to configure for this.
1. I installed base  in /usr/local/EPICS
2. The source for base (3.14.9) is in /usr/local/EPICSSRC/base
3. Sequencer (2.0.11) is uncompressed into /usr/local/EPICSSRC/modules/soft/seq
4. I've set INSTALL and INSTALL_APP to install everything in /usr/local/EPICS
Now, I'm working on the RELEASE file in my application.
According to the documentation I set SNCSEQ to the directory where you installed the sequencer.
   Is that where the executables are, or where I unpacked the source into?
It looks like I need to pull in the RULES_BUILD file from the sequencer directory, but how do I do that without accessing the source copy?
David Dudley
Re: Working with sequencer Benjamin Franksen
Prev: archiveviewer - Error in data header Devin Bougie
Next: Re: archiveviewer - Error in data header Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: archiveviewer - Error in data header Kasemir, Kay
Next: Re: Working with sequencer Benjamin Franksen
