Hi:
That error
> ../DataFile.cpp (105): Cannot reference '/arch/data/...'
which happens when you look at a wide time range is actually
caused by running out of file descriptors.
I've tried to keep data files open while processing one request
just in case I need to access that file again,
but eventually you might have too many files open
and then you get that error.
In Storage/RawDataReader.cpp around line 215 you should find
the start of the RawDataReader::getHeader() method.
Add a
DataFile::clear_cache();
as shown below to close previously opened data files
before opening a new one.
-Kay
void RawDataReader::getHeader(const stdString &basename, FileOffset offset)
if (!Filename::isValid(basename))
throw GenericException(__FILE__, __LINE__, "'%s': Invalid basename",
channel_name.c_str());
try
AutoPtr<DataHeader> new_header;
{ // Read new header
DataFile *datafile;
if (basename[0] == '/') // Index gave us the data file with the
full path
datafile = DataFile::reference("", basename, false);
else // Look relative to the index's directory
datafile = DataFile::reference(index_result->getDirectory(),
basename, false);
// If we keep opening data files, we'll hit the max-open-files
limit.
// Close files which are no longer referenced:
try
new_header = datafile->getHeader(offset);
On 11/20/08 15:36 , "Devin Bougie" <[email protected]> wrote:
> Hi, All. We've started to see "Error in data header" errors when
> trying to view more than 55 days of archived data for some channels.
> For example, if I try to plot from "-55d" to "now", everything works.
> If I try to plot from "-56d" to "now" I get an error. Likewise,
> "-60d" to "-5d" works, but "-60d" to "-4d" does not.
> Is there anything I should look at or try before using ArchiveDataTool
> to copy the existing archive to a new one? Here are examples of some
> of the errors we see in archserver.log.
> Many thanks,
> Devin
> 11/20/2008 14:50:31 ---- ArchiveServer 2.9.2 Started ----
> 11/20/2008 14:50:31 Client: Apache XML-RPC 1.2-a3-dev @
> 128.84.45.100:33129
> 11/20/2008 14:50:31 archiver.get_values
> 11/20/2008 14:50:31 how=3, count=785
> 11/20/2008 14:50:31 get_channel_data
> 11/20/2008 14:50:31 Method: Plot-Binning, 6168.15 sec bins
> 11/20/2008 14:50:31 Start: 09/25/2008 14:50:31.824000000
> 11/20/2008 14:50:31 End : 11/20/2008 14:50:31.824000000
> 11/20/2008 14:50:31 Open index, key 1 = '/arch/all.xml'
> 11/20/2008 14:50:31 Handling 'YP1FIA02_GFL_cplr1_win'
> 11/20/2008 14:50:36 Error:
> ../RawDataReader.cpp (277): Error in data header '/arch/data/l0',
> '2008/11_19/20081119-3' @ 0x00D615F7 for channel 'YP1
> FIA02_GFL_cplr1_win'.
> l0/2008/11_19/20081119-3'
> 11/20/2008 14:50:36 ArchiveServer ran 4.17315 seconds
> 11/20/2008 14:51:54 ---- ArchiveServer 2.9.2 Started ----
> 11/20/2008 14:51:54 Client: Apache XML-RPC 1.2-a3-dev @
> 128.84.45.100:33136
> 11/20/2008 14:51:54 archiver.get_values
> 11/20/2008 14:51:54 how=3, count=785
> 11/20/2008 14:51:54 get_channel_data
> 11/20/2008 14:51:54 Method: Plot-Binning, 6278.22 sec bins
> 11/20/2008 14:51:54 Start: 09/24/2008 14:51:54.715000000
> 11/20/2008 14:51:54 End : 11/20/2008 14:51:54.715000000
> 11/20/2008 14:51:54 Open index, key 1 = '/arch/all.xml'
> 11/20/2008 14:51:54 Handling 'YP1FIA02_GFL_cplr1_win'
> 11/20/2008 14:51:58 Error:
> '2008/11_18/20081118-5' @ 0x01410958 for channel 'YP1
> l0/2008/11_18/20081118-5'
> 11/20/2008 14:51:58 ArchiveServer ran 4.17804 seconds
> 11/20/2008 14:52:35 ---- ArchiveServer 2.9.2 Started ----
> 11/20/2008 14:52:35 Client: Apache XML-RPC 1.2-a3-dev @
> 128.84.45.100:33137
> 11/20/2008 14:52:35 archiver.get_values
> 11/20/2008 14:52:35 how=3, count=785
> 11/20/2008 14:52:35 get_channel_data
> 11/20/2008 14:52:35 Method: Plot-Binning, 6058.09 sec bins
> 11/20/2008 14:52:35 Start: 09/21/2008 14:52:35.093000000
> 11/20/2008 14:52:35 End : 11/15/2008 14:52:35.093000000
> 11/20/2008 14:52:35 Open index, key 1 = '/arch/all.xml'
> 11/20/2008 14:52:35 Handling 'YP1FIA02_GFL_cplr1_win'
> 11/20/2008 14:52:39 Error:
> '2008/11_15/20081115-13' @ 0x01C6AADE for channel 'YP
> 1FIA02_GFL_cplr1_win'.
> l0/2008/11_15/20081115-13'
> 11/20/2008 14:52:39 ArchiveServer ran 4.14733 seconds
- archiveviewer - Error in data header Devin Bougie
Working with sequencer David Dudley
Re: Working with sequencer Benjamin Franksen
<2008>
2025
2026
<2008>
2025
2026
