1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error from Autosave version 4-4
To: [email protected]
Cc: "Sherry Y. Chu" <[email protected]>
Date: Mon, 24 Nov 2008 17:37:23 -0800
I am getting the following error from autosave version 4-4:
create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM1:motor")
0x00000000 (0)
create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM1:motor")
0x00000000 (0)
create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM2:motor")
save_restore:create_data_set: 'motor_positions.req' already in c mode0xffffffff (-1)
create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM2:motor")
save_restore:create_data_set: 'motor_settings.req' already in c mode0xffffffff (-1)
create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM3:motor")
create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM3:motor")
I guess this means that it is not reentrant like the sequencer?
In any case, we will do the request file like this:
========= motor_positions.req =================
$(P):CM1:motor.DVAL
$(P):CM1:motor.OFF
$(P):CM2:motor.DVAL
$(P):CM2:motor.OFF
$(P):CM3:motor.DVAL
$(P):CM3:motor.OFF
Thanks, Ernest
Re: Error from Autosave version 4-4 Tim Mooney
Prev: areaDetector R1-3 released Mark Rivers
Next: Re: Error from Autosave version 4-4 Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
