1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error from Autosave version 4-4
To: "Ernest L. Williams Jr." <[email protected]>
Cc: "Sherry Y. Chu" <[email protected]>, [email protected]
Date: Mon, 24 Nov 2008 20:30:59 -0600
Ernest, Autosave doesn't (currently) permit a request file to be used
more than once in a create_*_set() call, because I neglected to code for
this possibility when I added macro substitution.  You can, nevertheless,
have nearly the effect you want, in the following way:
Make files I'll call all_motor_positions.req, and all_motor_settings.req,
with the following content:
all_motor_positions.req:
file motor_positions.req M=CM1:motor
file motor_positions.req M=CM2:motor
all_motor_settings.req:
file motor_settings.req M=CM1:motor
file motor_settings.req M=CM2:motor
Include the following function calls in place of the ones in your email:
create_monitor_set("all_motor_positions.req", 5, "P=U01:")
create_monitor_set("all_motor_settings.req", 5, "P=U01:")
The include files, motor_positions.req and motor_settings.req, must occur in
a directory included in autosave's requestfile path to be found.  (See
set_requestfile_path(), in autosave's docs.)
I'll look into what would be required for autosave to work as your first try
expects.  It probably won't be pretty, because (IIRC) autosave has the notion
of a file name directly representing a save set buried pretty deeply into its
structure.  Also, it won't happen until after synApps 5.4.
Tim
Ernest L. Williams Jr. wrote:
I am getting the following error from autosave version 4-4:
create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM1:motor")
0x00000000 (0)
create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM1:motor")
0x00000000 (0)
create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM2:motor")
save_restore:create_data_set: 'motor_positions.req' already in c mode0xffffffff (-1)
create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM2:motor")
save_restore:create_data_set: 'motor_settings.req' already in c mode0xffffffff (-1)
create_monitor_set("motor_positions.req", 5, "P=U01:, M=CM3:motor")
create_monitor_set("motor_settings.req", 30, "P=U01:, M=CM3:motor")
I guess this means that it is not reentrant like the sequencer?
In any case, we will do the request file like this:
========= motor_positions.req =================
$(P):CM1:motor.DVAL
$(P):CM1:motor.OFF
$(P):CM2:motor.DVAL
$(P):CM2:motor.OFF
$(P):CM3:motor.DVAL
$(P):CM3:motor.OFF
Thanks, Ernest
-- Tim Mooney ([email protected]) (630)252-5417 Beamline Controls & Data Acquisition Group Advanced Photon Source, Argonne National Lab.
Error from Autosave version 4-4 Ernest L. Williams Jr.
Prev: Error from Autosave version 4-4 Ernest L. Williams Jr.
Next: RE: solaris-x86 build error on 3.14.10 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: sscan compile error on base 3.14.10 on linux John M. Skinner
