1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: solaris-x86 build error on 3.14.10
To: <[email protected]>
Date: Mon, 24 Nov 2008 22:54:32 -0600
I've figured out why the linking of libCom.so was failing on solaris-sparc.  The problem is that -lCrun must come AFTER -lCstd in the link line, because Cstd refers to functions in Crun, and it must be a one-pass linker?
I fixed this by changing the definition of STLPORT_LDLIBS_NO in CONFIG.Common.solaris-sparc.  I don't know if this is the best solution, but it does allow 3.14.10 to build on Solaris.
Here's the change I made:
RCS file: /net/phoebus/epicsmgr/cvsroot/epics/base/configure/os/CONFIG.Common.solaris-sparc,v
retrieving revision 1.15.2.21
diff -u -r1.15.2.21 CONFIG.Common.solaris-sparc
--- configure/os/CONFIG.Common.solaris-sparc    7 Oct 2008 22:17:17 -0000       1.15.2.21
+++ configure/os/CONFIG.Common.solaris-sparc    25 Nov 2008 04:46:11 -0000
@@ -40,7 +40,7 @@
 STLPORT_CFLAGS_YES= -library=stlport4
 STLPORT_CFLAGS_NO=
 STLPORT_LDLIBS_YES =
-STLPORT_LDLIBS_NO = -lCstd
+STLPORT_LDLIBS_NO = -lCstd -lCrun
 # can be overridden in CONFIG_SITE.Common.solaris-sparc
 USE_STLPORT=NO
Sent: Sat 11/22/2008 3:09 PM
To: '[email protected]'
I was actually making a mistake, the machine was a sparc, not x86.
But I get the same error when I correct that mistake and build for solaris-sparc when linking libCom.so:
make[2]: Entering directory `/corvette/usr/local/epics/base-3.14.10/src/libCom'
make -C O.solaris-sparc -f ../Makefile TOP=../../.. T_A=solaris-sparc install
make[3]: Entering directory `/corvette/usr/local/epics/base-3.14.10/src/libCom/O.solaris-sparc'
/opt/SUNWspro/bin/CC -o libCom.so.3.14 -z defs -G -h libCom.so.3.14 -z text            -mt  -z ignore -z combreloc -z lazyload             bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent!
 .o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o     -lposix4 -lpthread     -lm -lsocket -lnsl -lumem -lCrun -lc -lCstd
Undefined                       first referenced
 symbol                             in file
void*__Crun::vector_del(void*,unsigned,void(*)(void*)) /opt/SUNWspro/prod/lib/libCstd.a(locale.o)
void*__Crun::vector_new(void*,unsigned,unsigned,void(*)(void*),void(*)(void*)) /opt/SUNWspro/prod/lib/libCstd.a(locale.o)
void operator delete(void*,void*)                      /opt/SUNWspro/prod/lib/libCstd.a(zOtiZS4hQ7CvMDXtQoDv.o)
ld: fatal: Symbol referencing errors. No output written to libCom.so.3.14
make[3]: *** [libCom.so.3.14] Error 1
make[3]: Leaving directory `/corvette/usr/local/epics/base-3.14.10/src/libCom/O.solaris-sparc'
make[2]: *** [install.solaris-sparc] Error 2
make[2]: Leaving directory `/corvette/usr/local/epics/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/corvette/usr/local/epics/base-3.14.10/src'
make: *** [src.install] Error 2
Sent: Fri 11/21/2008 6:49 PM
Subject: solaris-x86 build error on 3.14.10
I'm trying to build 3.14.10 on solaris-x86.
I get the following error when building libCom.a
/opt/SUNWspro/bin/CC -xar -o   libCom.a         bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epic!
 .o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLib.o devLibOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o     -lposix4 -lpthread     -lm -lsocket -lnsl -lCrun -lc -lCstd
 symbol                             in file
Can anyone tell me what the problem is?
Versions:
SunOS 5.10
CC: Sun C++ 5.8 Patch 121017-13 2008/01/02
Re: solaris-x86 build error on 3.14.10 Andrew Johnson
solaris-x86 build error on 3.14.10 Mark Rivers
RE: solaris-x86 build error on 3.14.10 Mark Rivers
Prev: Re: Error from Autosave version 4-4 Tim Mooney
Next: sscan compile error on base 3.14.10 on linux John M. Skinner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: solaris-x86 build error on 3.14.10 Mark Rivers
Next: Re: solaris-x86 build error on 3.14.10 Andrew Johnson
