1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: sscan compile error on base 3.14.10 on linux
Cc: "John M. Skinner" <[email protected]>, [email protected]
Date: Wed, 26 Nov 2008 11:14:52 -0600
Note that the cvs version of sscan contains modifications that split
the busy record out into a separate module.  If you're not ready to
do that, you could just back out the changes in sscanApp/src/Makefile
and sscanApp/src/sscanSupport.dbd.
Mark Rivers wrote:
John,
You can get the CVS version of sscan at:
http://cars.uchicago.edu/software/pub/sscanHEAD.tgz
This has some changes beyond the version I have tested, but it should
work.
-----Original Message-----
[mailto:[email protected]] On Behalf Of John M. Skinner
Sent: Wednesday, November 26, 2008 10:43 AM
To: [email protected]
Subject: sscan compile error on base 3.14.10 on linux
I'm trying to build sscan 2.6.2 on EPICS base 3.14.10 but get these compile warnings and errors:
../sscanRecord.c: In function `special':
../sscanRecord.c:1451: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c:1585: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `notifyCallback':
../sscanRecord.c:2457: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `userGetCallback':
../sscanRecord.c:2523: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `pvSearchCallback':
../sscanRecord.c:2613: error: incompatible types in assignment
../sscanRecord.c:2643: error: incompatible types in assignment
../sscanRecord.c:2743: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `posMonCallback':
../sscanRecord.c:2818: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c: In function `doPuts':
../sscanRecord.c:4013: warning: passing arg 1 of `scanOnce' from incompatible pointer type
../sscanRecord.c:4190: warning: passing arg 1 of `scanOnce' from incompatible pointer type
I get the same results on both Fedora Core 3 and Fedora Core 8. I have no problem building the scan record on EPICS base 3.14.9.
thanks,
John Skinner (BNL/NSLS)
-- Tim Mooney ([email protected]) (630)252-5417 Beamline Controls & Data Acquisition Group Advanced Photon Source, Argonne National Lab.
Re: sscan compile error on base 3.14.10 on linux John M. Skinner
RE: sscan compile error on base 3.14.10 on linux Mark Rivers
Prev: Re: sscan compile error on base 3.14.10 on linux John M. Skinner
Next: Re: sscan compile error on base 3.14.10 on linux John M. Skinner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
