1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: questions about stepper motor
To: "Xu, Huijuan" <[email protected]>
Cc: [email protected]
Date: Wed, 26 Nov 2008 21:08:48 -0600
Help us to understand your particular use.
When you say that you want to 'keep the motor moving all the time for several months," there are a couple ways that might be interpreted. One is that the motor will continue to rotate in the same direction without stopping for months. Another interpretation is that the motor will remain under power for several months and occasionally be commanded to move within a specific and limited range of steps. (This latter case is very typical for our use of stepper motors.)
Which case is yours?
Perhaps if you have the first case (such as a sample spinner), a stepper motor might not be the best solution.
Pete
Kurt Goetze wrote:
Hi Huijuan, Re:
Xu, Huijuan wrote:
I will evaluate the performance of the stepper motor. When doing this, I want to keep the motor moving all the time for several months. Is there anyone who did the similar thing before? I can’t find any reference to continuous motion.
To run the stepper for this long you could also connect a
function generator's square wave output to the step input
of your driver.
Kurt
questions about stepper motor Xu, Huijuan
Re: questions about stepper motor Kurt Goetze
Prev: Re: questions about stepper motor Kurt Goetze
Next: nidaqmxbase synapps module Terry Cornall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
