On Tuesday 02 December 2008 11:19:50 David Dudley wrote:
> I read in section 12.5.6 (page 186) of the "IOC Application Developers
> Guide" that the Init Record routine calculates ESLO and EOFF.
> Do I need to do that from within my device driver, or is it done
> automatically somewhere?
The record support code doesn't know the raw range of your analog I/O values,
so it can't calculate ESLO for you. That's why your ai/ao device support is
responsible for setting it, in both the Init Record and Special Linear
Conversion routines. You only need to set EOFF if its value is not the same
as EGUL, so in most cases the calculation is a one liner, e.g. for a 16-bit
ADC/DAC:
prec->eslo = (prec->eguf - prec->egul)/65535.0;
The device's special_linconv() routine is only called when LINR is LINEAR; the
user can set ESLO and EOFF manually when LINR is SLOPE.
Of course this all assumes that your device support is using the RVAL field;
if it directly handles floating-point values in the VAL field then LINR,
EGUL, EGUF, ESLO and EOFF are not relevent anyway.
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: Device Driver Initialization routine David Dudley
- Device Driver Initialization routine David Dudley
Re: sscan compile error on base 3.14.10 on linux Andrew Johnson
<2008>
2025
2026
<2008>
2025
2026
