1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Records not in Base
To: [email protected]
Date: Wed, 3 Dec 2008 15:38:49 -0600
On Wednesday 03 December 2008 14:32:09 David Dudley wrote:
> Is there some specific reason that some of these other records *aren't* a
> part of base?
> For instance, Archive seems pretty handy from reading the documentation, as
> does Timer, and especially ePID (which isn't in the wiki).
AFAIK the archive record is pretty specific to the DESY archiver, which is
different to the channel archiver.  The timer record is also included in the
unbundled Mizar support and probably rather specific.  There used to be a PID
record in Base, but it had a few problems and various other people developed
enhanced versions, of which I believe the ePID to be the best.  However
either they were never offered back to Base or it was felt they were better
maintained independently.
> How did the specific records in base get -canonized- to be a part of base?
History and authorship/maintenance.  The majority of the record types in Base
date back to the original GTACS code.  A number of record types have been
added and removed over the years; in between 3.13 and 3.14 we removed several
as part of the un-bundling of all hardware-specific device and record support
from Base.  That was when the Mizar support module got created for example.
I added the aSub record in R3.14.10 because there were many people using the
genSub record from which it was derived, and it's a very useful generic
thing.
> Is there any reason for these other records to *not* be considered for
> inclusion into base?
They are better off being separately maintained; this spreads the workload
across the community, and means that if nobody uses them they naturally stop
taking up maintenance effort.  As it is there are a few record types in Base
that are probably not being used, so they'll probably get unbundled for the
next major release.
My aim is actually to reduce the size of Base rather than increase it; one of
my plans is to split Base into 3 or more parts - Core, CA (or CAC and CAS)
and IOC and allow them all to evolve separately.  I'm keen to get other
people to create different EPICS Distros containing a particular collection
of modules that make up a complete EPICS toolkit.  I expect synApps to become
one such Distribution.
HTH,
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
Re: Records not in Base Maren Purves
Records not in Base David Dudley
Re: Records not in Base Andrew Johnson
Re: Records not in Base David Dudley
Prev: Re: Records not in Base David Dudley
Next: Re: Records not in Base Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
