Andrew Johnson wrote:
On Wednesday 03 December 2008 14:32:09 David Dudley wrote:
Is there some specific reason that some of these other records *aren't* a
part of base?
Is there any reason for these other records to *not* be considered for
inclusion into base?
They are better off being separately maintained; this spreads the workload
across the community, and means that if nobody uses them they naturally stop
taking up maintenance effort.
Here's an example: some 10 or so years back I needed a sequence record
with more 'output legs' than the regular sequence record, so I made
one. Most people probably long since forgot it exists, but when I
needed one again I knew where to find it. A lot of the records that
are not in base are rather specialized ...
Aloha,
Maren
- Records not in Base David Dudley
- Re: Records not in Base Andrew Johnson
- Re: Records not in Base David Dudley
Re: Re: compile error about gateway Silver
<2008>
2025
2026
Re: Records not in Base Nicholas P. DiMonte
<2008>
2025
2026
