1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Records not in Base
To: David Dudley <[email protected]>
Date: Thu, 04 Dec 2008 10:22:15 -0600
David Dudley wrote:
I see references to various records in the 3.14 wiki that are not a part of base.
The ones I've seen so far are Pulse Counter, Pulse Delay, Pulse Train, and Transform.  There are probably more, but the Pulse ones in particular interested me for a project coming up.
Transform, I see if a soft module extension, but where do I find the Pulse records?  Also, wouldn't it kinda make sense to at least indicate in the wiki page where the module is available from (perhaps not exact location, but "a part of base", or "from modules/soft", or something)?
David Dudley
David,
Funny you mention this. I'm in the middle of converting my IOC app areas to 3.14 from 3.13 and discovered the pulse records were not included in base. Since I use this record and not the Mizar hardware, I have created a  separate support module for the pulse records. I will be working with Andrew on this and should be updating the epics web pages with these changes soon. I'll inform you when I'm done.
Nick DiMonte
ANL/APS Controls
Records not in Base David Dudley
Prev: Re: Re: compile error about gateway Silver
Next: Re: NTP-Time on RTEMS(vxWorks) Problem Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Records not in Base Maren Purves
Next: Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
