Hi Jens,
On Friday 28 November 2008 06:45:50 Jens Eden wrote:
> we found a problem when synchronizing Time on RTEMS targets
> with the new NTP-TimeProvider in Release 3.14.10.
Thanks for the report and patch. I would be interested to see the output from
an "NTPTime_Report 1" command gives on that system, with or without your fix,
since that report displays the measured tick rate as well as the nominal one
and your report implies the two were significantly different.
I did wonder whether the NTP time provider should correct for problems caused
by an incorrect clock tick rate since it is able to detect them, but I was
persuaded by Eric Norum not to do so.
> Attached is a patch to set the IOC-time in all cases.
I have made this change in CVS and added a patch to the Known Problems page.
- Andrew
Talk is cheap. Show me the code. -- Linus Torvalds
- Re: NTP-Time on RTEMS(vxWorks) Problem Jens Eden
- NTP-Time on RTEMS(vxWorks) Problem Jens Eden
Re: Records not in Base Nicholas P. DiMonte
Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
<2008>
2025
2026
<2008>
2025
2026
