1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: NTP-Time on RTEMS(vxWorks) Problem
Cc: [email protected]
Date: Fri, 05 Dec 2008 12:47:09 +0100
Hi Andrew,
> Thanks for the report and patch.  I would be interested to see the output from
> an "NTPTime_Report 1" command gives on that system, with or without your fix,
> since that report displays the measured tick rate as well as the nominal one
> and your report implies the two were significantly different.
This is the output of NTPTime_Report
NTP driver is synchronized with server
Syncronization interval = 60.0 seconds
Last synchronized at 2008-12-05 10:10:28.001558
OS tick rate = 50 Hz (nominal)
Measured tick rate = 50.002 Hz
> I did wonder whether the NTP time provider should correct for problems caused
> by an incorrect clock tick rate since it is able to detect them, but I was
> persuaded by Eric Norum not to do so.
The measured tick rate is pretty close to the nominal tick rate and it took
several hours until the ticksToSkip-counter had accumulated enough ticks to
halt the IOC-Time for about 2 seconds. I consider this as a "normal"
incorrect clock tick rate.
Btw. The problem didn't occur, if running the EPICS example application on the
same hardware. I had to use a real-world application (reading Keitley-devices
via GPIB and doing average calculations). But then I was able to reproduce
it on another IOC with similar hardware.
I believe, as long as the jitter of the osdNTPGet-call was big enough to return
a time value every now and then, which didn't need to skip a tick, the IOC-time
was adjusted and the problem did not occur.
Regards
Jens
NTP-Time on RTEMS(vxWorks) Problem Jens Eden
Re: NTP-Time on RTEMS(vxWorks) Problem Andrew Johnson
Prev: Re: How to implement simple control algorithm (one more question) Ralph Lange
Next: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Steve Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: NTP-Time on RTEMS(vxWorks) Problem Andrew Johnson
Next: Re:RE: Use of waveform records marco_hair
