Channel Access limits strings to 40 characters. So you will only be able
to set/read your long strings locally on the IOC, not across the network.
Ralph
Kalantari Babak wrote:
I do not have a precise answer to this question, maybe others can
comment on it.
What might be a disadvantage is that you have to take care of your
customization whenever you try your database with other EPICS versions
(e.g. upgrade) and therefore your database would have a problem to work
with a normal ("standard") EPICS distribution.
Babak
-----Original Message-----
Sent: Freitag, 5. Dezember 2008 09:29
Thank you for your answer.
I'd like to ask one more question:
Is it ok to break 40 chars limit in CALC field( or another text fields
like DESC) ?
I've changed this limit to 200 in calcoutRecord.dbd, db_access.c and
epicsTypes.h (MAX_STRING_SIZE define) and it works ok
- Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
- RE: How to implement simple control algorithm (one more question) Kalantari Babak
Re: NTP-Time on RTEMS(vxWorks) Problem Jens Eden
<2008>
2025
2026
RE: How to implement simple control algorithm (one more question) Dalesio, Leo
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
