1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to implement simple control algorithm (one more question)
To: "Ilya V. Kitaev" <[email protected]>, "Kalantari Babak" <[email protected]>
Cc: [email protected]
Date: Sun, 28 Dec 2008 10:02:47 -0500
YOu can make the strings as long as you like. You just can't set or get them through channel access then - a 40 character limit. I'm not sure that it handles this properly. Jeff or someone else should comment on that.
Bob
-----Original Message-----
From: [email protected] on behalf of Ilya V. Kitaev
Sent: Fri 12/5/2008 3:29 AM
To: Kalantari Babak
Subject: Re: How to implement simple control algorithm (one more question)
Thank you for your answer.
I'd like to ask one more question:
Is it ok to break 40 chars limit in CALC field( or another text fields
like DESC) ?
I've changed this limit  to 200 in calcoutRecord.dbd, db_access.c and
epicsTypes.h (MAX_STRING_SIZE define) and it works ok.
2008/12/3, Kalantari Babak <[email protected]>:
> Hi,
> You do not need to write your own CA application for that.
> Monitor alarm status of your "ai" with a "calcout" record and write to
> your "bo" upon occurrence of the conditions.
> This can be done for example as the following:
> record(calcout, "$(ALGORITHM)")
>         field(INPA,"$(YOUR_AI_REC).STAT CP") # monitoring
>         field(INPB,"$(YOUR_BO_REC).VAL NPP")
>         field(CALC, "A=3?1:A=5?0:B")
>         field(OOPT, "On Change")
>         field(OUT,"$(YOUR_BO_REC) PP")
> Alarm status value for HIHI is 3 and for LOLO is 5.
> HTH,
> Babak
Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
Prev: Re: edm help Ernest L. Williams Jr.
Next: Timezone setting with R3.14.10 Dehong Zhang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to implement simple control algorithm (one more question) Ralph Lange
Next: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Steve Banks
