1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: edm help
To: "Szalata, Zenon M." <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Fri, 26 Dec 2008 18:37:57 -0800
Szalata, Zenon M. wrote:
I have created a new edm widget by following the "Creating edm widgets" document. I have it mostly working and would like to add online help for it. I see that I could modify the helpObjects.edl file in the edm distribution. I wonder if there is a way to add help without modifying any files in the edm package? What is the best or correct way to add online help for new widget?
Zen
Hi Zen,
The "helpObjects.edl" should actually be installed outside of the source distribution and its loication defined by
the "EDMHELPFILES" environment variable.
One way to have the helpFiles be automatically installed with the EPICS Make system is to introduce Makefile and rules
to $EXTENSIONS_TOP/src/edm/helpFiles. The same kind of thing should could be done for other things such as colors.list, etc...
Currently, things get setup in $EXTENSIONS_TOP/src/edm/setup/setup.sh. Take a look at that script.
Thanks, Ernest
edm help Szalata, Zenon M.
Prev: edm help Szalata, Zenon M.
Next: RE: How to implement simple control algorithm (one more question) Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Timezone setting with R3.14.10 Dehong Zhang
