1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to implement simple control algorithm (one more question)
To: "Ilya V. Kitaev" <[email protected]>
Cc: [email protected]
Date: Fri, 5 Dec 2008 11:27:37 +0100
I do not have a precise answer to this question, maybe others can
comment on it.
What might be a disadvantage is that you have to take care of your
customization whenever you try your database with other EPICS versions
(e.g. upgrade) and therefore your database would have a problem to work
with a normal ("standard") EPICS distribution.
Babak
> -----Original Message-----
> From: Ilya V. Kitaev [mailto:[email protected]]
> Sent: Freitag, 5. Dezember 2008 09:29
> Hi,
> Thank you for your answer.
> I'd like to ask one more question:
> Is it ok to break 40 chars limit in CALC field( or another text fields
> like DESC) ?
> I've changed this limit  to 200 in calcoutRecord.dbd, db_access.c and
> epicsTypes.h (MAX_STRING_SIZE define) and it works ok.
Re: How to implement simple control algorithm (one more question) Ralph Lange
Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
Prev: Re: How to implement simple control algorithm (one more question) Ilya V. Kitaev
Next: Re: How to implement simple control algorithm (one more question) Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
