1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: motor unrecoverable exception
To: "Xu, Huijuan" <[email protected]>
Cc: [email protected]
Date: Mon, 08 Dec 2008 12:58:57 -0600
Hello Huijuan,
Just to be clear; I presume this is an "medm" exception you are experiencing.
What host platform is medm running on (OS, OS version, CPU, etc.)?
Which version of medm?
Best regards,
Ron
Xu, Huijuan wrote:
Hello,
Fatal error is encountered when motorx_all.adl is used to change the parameters of stepper motor.
When the JOGR or JOGF button is pressed, a fatal error is showed as follows.
>Oops, Exception 8 in interrupt handler
         Next PC or Address of fault = 1984AC, Saved MSR = 9032
         R0  = 000B6C10 R1  = 00263DE8 R2  = 00000000 R3  = 00000000
         R4  = 002644EC R5  = 00C07754 R6  = 002644E0 R7  = 00000000
         R8  = 00000000 R9  = 00264548 R10 = 00000020 R11 = 00C34D3C
         R12 = 40000004 R13 = 00250FC0 R14 = 00250000 R15 = 00250000
         R16 = 002644E0 R17 = 00250000 R18 = FFFFFFFF R19 = 00250000
         R20 = 00250000 R21 = 00000000 R22 = 00200000 R23 = 00000000
         R24 = 002644EC R25 = 00252374 R26 = 00000001 R27 = 9FFFF000
         R28 = 01000000 R29 = 00C07754 R30 = 0024F084 R31 = 00000000
         CR  = 40000004
         CTR = 0018EEEC
         XER = 20000000
         LR  = 00198474
         DAR = 00000000
Stack Trace:
  IP: 0x001984AC, LR: 0x00198474
--^ 0x0018EFB4--^ 0x00B16368--^ 0x001063E0--^ 0x000E400C--^ 0x000E493C
FATAL: unrecoverable exception without a task context
Also, when clicked Tweak Go button in motorx_more.adl, same error occurs.
Any information would be appreciated.
motor unrecoverable exception Xu, Huijuan
Prev: EDM On Focus Related Displays Won't Close Brian Bevins
Next: ioc running on a server with a private network Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: motor unrecoverable exception Xu, Huijuan
Next: EDM On Focus Related Displays Won't Close Brian Bevins
