1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ioc running on a server with a private network
To: "EPICS Tech Talk" <[email protected]>
Date: Mon, 8 Dec 2008 17:42:14 -1000
Hi All,
I have an R3.14.9 Unix IOC running on a Solaris-8 host that actually has two IP addresses. The 2nd IP is setup for a private network.
When I access a channel from this IOC, it warns me about multiple IOCs and references both IP addresses assigned to this server, the primary address and the private network address.
I have worked around it by using EPICS_CA_AUTO_ADDR_LIST=NO and EPICS_CA_ADDR_LIST=’primary IP’ but am curious why this is happening and if there is another way around this.
Thank you,
Kevin Tsubota
W.M. Keck Observatory
Re: ioc running on a server with a private network Dirk Zimoch
Prev: Re: motor unrecoverable exception Ron Sluiter
Next: Re: ioc running on a server with a private network Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EDM On Focus Related Displays Won't Close John Sinclair
