Hello,
By default, channel access uses all broadcast addresses it finds on the host.
That means an IOC is server on both network cards and a client searches on both
network cards. Thus, when client and IOC run on the same machine, you get
duplicate channel warnings. Setting EPICS_CA_AUTO_ADDR_LIST=NO and
EPICS_CA_ADDR_LIST=’primary IP’ on hosts with two network cards is the correct
way to solve this problem. Best do it automatically for every user in a script
in /etc/profile.d/.
Dirk
Kevin Tsubota wrote:
Hi All,
I have an R3.14.9 Unix IOC running on a Solaris-8 host that actually has
two IP addresses. The 2^nd IP is setup for a private network.
When I access a channel from this IOC, it warns me about multiple IOCs
and references both IP addresses assigned to this server, the primary
address and the private network address.
I have worked around it by using EPICS_CA_AUTO_ADDR_LIST=NO and
EPICS_CA_ADDR_LIST=’primary IP’ but am curious why this is happening and
if there is another way around this.
Thank you,
Kevin Tsubota
W.M. Keck Observatory
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
- ioc running on a server with a private network Kevin Tsubota
DeltaTau UMAC ethernet access? Dirk Zimoch
<2008>
2025
2026
<2008>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
