1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: DeltaTau UMAC ethernet access?
To: tech-talk <[email protected]>
Date: Tue, 09 Dec 2008 15:05:17 +0100
Hi all,
Is there a driver for the DeltaTau UMAC ethernet interface?
I could only find drivers for VME based or PCI based PMAC controllers but not for controllers (Turbo PMAC 2 CPU) connected via ethernet or USB. The protocol seems to be the same as for other DeltaTau controller types, only the data transfer layer is different (uses UDP). A typical case for asynOctet, I think.
Dirk
Dr. Dirk Zimoch
Paul Scherrer Institut, WBGB/006
5232 Villigen PSI, Switzerland
Phone +41 56 310 5182
RE: DeltaTau UMAC ethernet access? Rees, NP (Nick)
Prev: Re: ioc running on a server with a private network Dirk Zimoch
Next: RE: DeltaTau UMAC ethernet access? Rees, NP (Nick)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
