1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about WebCA
To: Bao Chunlei <[email protected]>
Date: Fri, 12 Dec 2008 08:33:29 -0500
What is the type and the value of "values" when you are attempting this operation? The "values" variable is either a scalar or an array depending on the number of items returned by the PV. Then you need to consider the native type of the PV. If the native type is a number then you need to convert it to a string in order to use the "indexOf" method. I suspect that your PV may be returning a number which is why the indexOf method fails. You might try looking in your web browser's JavaScript console log to see if there are any errors.
To test for an array, check whether values.length is defined.
To get the type, use the "typeof" method as in "typeof(values)".
best regards,
tom
On Dec 11, 2008, at 8:18 PM, Bao Chunlei wrote:
Hello all,
I just use WebCA to read pv value.But when I do some change to the value,I get nothing.If anyone has the answer,please tell me.
the code:
function handleMonitor( userInfo, pvName, values, status, severity, timestamp ) {
userInfo.innerHTML = values;
only this,is run correct.
but
temp=values;
index=0;
index=temp.indexOf(".");
userInfo.innerHTML = temp.substr(0,index+4);
I get nothing value。
Thanks all
Baochunlei
Control Group,IHEP
Question about WebCA Bao Chunlei
Prev: Re: lockset question Benjamin Franksen
Next: Re: EDM On Focus Related Displays Won't Close John Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Question about WebCA Bao Chunlei
Next: Problems getting edm functional on NetBSD David Dudley
