1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problems getting edm functional on NetBSD
To: tech-talk <[email protected]>
Date: Mon, 15 Dec 2008 13:39:08 -0600
I'm working on getting edm operational on NetBSD.  I've got everything compiling correctly, however I'm having problems when I try to run the system.
For some reason, when I try to install libEpics.so, I get an error that it can't find object "nss_dns.so.0".  Also get the same error when I try to install libLog.so.  Without installing those two files, edm seems to run great, except, of course that parts of it won't work.
The errors are directly related to functions defined in the nsdispatch() OS module.  I thought it was related to the 'gethostbyname' calls used in edmMain/main.cc and lib/pvs.cc (which are the only two functions used which reference the library), however even with those commented out (just for a test), it still fails when trying to load the library.  This leads me to think that it probably is related to something in base, however everything else in base, and all the other extensions I've got built work without error, so I'm still pointed back to a problem with  the way edm links.
Have any wild ideas?  This is the last program I need to adapt to run on NetBSD.  I've got all of SDDS, ChannelArchiver, StripTool, alh, gateway, medm, and probe working fine.
The NetBSD group tells me that the nisdispatch functions are all contained in libc, and I've written small little test programs that link and run with no problem.
David
Prev: Re: lockset question Marty Kraimer
Next: Question on signals with Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <2008>  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about WebCA Tom Pelaia
Next: Re: Problems getting edm functional on NetBSD David Dudley
