There is a problem while downloading an "ao" record which is used for a peripheral I/O device named "PSC", part of the downloading console is like this: (OS is RTEMS, and EPICS version is 3.14.6) dbLoadRecords("../db/powersupply.db")
0x00000000 (0)
iocInit()
Starting iocInit
### EPICS IOC CORE built on Jan 9 2008
### EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
filename="../recGbl.c" line number=88
Bad init_rec return value PV: R4IBT04:CISet ao: init_record
0x00000000 (0)
iocInit: All initialization completeand contents of "R4IBT04:CISet" is as follows: record(ao,"R4IBT04:CISet") {
field(DESC, "analog output record")
field(SCAN, "Passive")
field(DTYP, "PSC")
field(OUT, "#C1 S0 @SPT")
field(PINI, "NO")
field(PHAS, "0")
field(EVNT, "0")
field(DISV, "1")
field(SDIS, "0.000000000000000e+00")
field(DISS, "NO_ALARM")
field(PRIO, "LOW")
field(FLNK, "0.000000000000000e+00")
field(OROC, "0.0000000e+00")
field(DOL, "0.000000000000000e+00")
field(OMSL, "supervisory")
field(OIF, "Full")
field(PREC, "3")
field(LINR, "NO CONVERSION")
field(EGUF, "0.0000000e+00")
field(EGUL, "0.0000000e+00")
field(EGU, "amps")
field(ESLO, "0.0000000e+00")
field(EOFF, "0.0000000e+00")
field(ASLO, "1.525902e-04")
field(AOFF, "-5.010000e+00")
field(DRVH, "0.0000000e+00")
field(DRVL, "0.0000000e+00")
field(HOPR, "4.545455e+00")
field(LOPR, "-4.545455e+00")
field(HIHI, "5.000000e+00")
field(LOLO, "-5.000000e+00")
field(HIGH, "0.0000000e+00")
field(LOW, "0.0000000e+00")
field(HHSV, "NO_ALARM")
field(LLSV, "NO_ALARM")
field(HSV, "NO_ALARM")
field(LSV, "NO_ALARM")
field(HYST, "0.000000000000000e+00")
field(ADEL, "0.000000000000000e+00")
field(MDEL, "0.000000000000000e+00")
field(SIOL, "0.000000000000000e+00")
field(SIML, "0.000000000000000e+00")
field(SIMS, "NO_ALARM")
field(IVOA, "Continue normally")
field(IVOV, "0.000000000000000e+00")}any help is appreciated, thanks a lot! Haoli Shi
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
