1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ao record downloading error
To: [email protected]
Date: Wed, 17 Dec 2008 09:30:02 -0600
On Wednesday 17 December 2008 07:54:55 Shi HaoLi wrote:
>     There is a problem while downloading an "ao" record which is used for a
> peripheral I/O device named "PSC", part of the downloading console is like
> this: (OS is RTEMS, and EPICS version is 3.14.6)
>     dbLoadRecords("../db/powersupply.db")
> 0x00000000 (0)
>     iocInit()
># Starting iocInit
> ###  EPICS IOC CORE built on Jan  9 2008
> ###  EPICS R3.14.6 $R3-14-6$ $2004/05/28 19:27:47$
># filename="../recGbl.c" line number=88
> Bad init_rec return value  PV: R4IBT04:CISet  ao: init_record
> 0x00000000 (0)
> iocInit: All initialization complete
This error message is generated by the ao record support when the device
support's init_record() routine returns any value other than 0 or 2; that's
all I can tell you based on your report.  You'll have to take a look at
the "PSC" device support for the ao record and work out why it's returning
something different, what it means and how to fix it.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
Re: ao record downloading error Shi HaoLi
Prev: ao record downloading error Shi HaoLi
Next: Firewire (IEEE 1394) support for areaDetector Pedersen, UK (Ulrik)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: ao record downloading error Shi HaoLi
