First time on tech-talk. Also new to epics.
I have been having trouble understanding why initial("init_value"), as a
rule within a field, works for some of my fields and not for others.
In my present ioc application I would prefer to initialize the field
from a substitutions file as then I can give individual initial values
to more than one process variable instead of one fixed value as defined
in the record .dbd file using initial.
I have included below, pieces from three files namely
st.cmd (the ioc startup command),
ioc.substitutions (a dbLoadTemplate file) and
iocpsc.db ( the .db that takes the substitutions from the pattern in
the substitute file)
in the st.cmd file I have:
dbLoadTemplate "../../db/ioc.substitutions"
in the ioc.substitutions file I have:
file ../../db/iocpsc.db {
pattern { ioc, pv, crate, module, chan, refval, refmax }
{ "ioc1", "eciv", "crate1", "0x00", 0, 20, 120 }
{ "ioc1", "ecii", "crate1", "0x00", 1, 0, 5 }
in the iocpsc.db file I have:
record(psc,"$(ioc):$(pv)")
field(SCAN, "1 second")
field(CRATE, "$(crate)")
field(MODULE ,"$(module)")
field(CHAN,$(chan))
field(REFVAL,$(refval))
field(REFMAX,$(refmax))
I find the strange effect that I can initialize the REFMAX field from
the substitutions file and in this case initial(120.0) below has no
effect, where as I cannot initialize the REFVAL field from the
substitutions file but it does initialize in the .dbd file to 12.0 as
initialized from the file below. Both fields are doubles defined in
pscRecord.h:
double refval; /*Reference Value*/
double refmax; /*Max Reference V - sets max*/
in the pscRecord.dbd file I have:
field(REFVAL, DBF_DOUBLE){
prompt("Reference Value")
asl(ASL1)
special(SPC_MOD)
initial(12.0)
field(REFMAX, DBF_DOUBLE){
prompt("Max Reference V - sets max")
asl(ASL1)
special(SPC_MOD)
initial (120.0)
In summary it seems that if initial has no effect in the .dbd file then
I can initialize the fields from the substitute file, which is the way I
would like to do it.
many thanks,
Ivan.
Re: SUB Record SNAM/INAM routine definition Tim Mooney
initial(init_value) rule within a field sometimes works - follow up ivan
<2008>
2025
2026
<2008>
2025
2026
