1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: initial(init_value) rule within a field sometimes works - follow up
To: [email protected]
Date: Wed, 24 Dec 2008 12:29:41 +0200
As is the nature of our profession just as you have mailed off a call
for help, one seems to find a solution.
I found that although I had done a make clean the iocpsc.db file that I
had created in the Db folder was not updated in the db folder after
make.  So manually copying the file to the db folder curred the problem.
I could then initialize all my fields from the substitute file.
Maybe there is another param for the make process that would have
updated this file, as I said "make clean" didn't do the trick.
Many thanks anyway,
Ivan
iThemba LABS, SA
Prev: initial(init_value) rule within a field sometimes works ivan
Next: Is it possible to implement a loop in db? ???
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  <20082009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
