1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: adding libCom calls to vxWorks IOC
To: "EPICS Tech-Talk" <[email protected]>
Date: Mon, 5 Jan 2009 13:31:20 -0500 (EST)
Forgive me if I am missing something obvious here, it is the first day
back after the holidays...
I am trying to use libCom calls to add an interrupt handler to device
support for a vxWorks (ppc604) IOC.
Everything compiles fine but at reboot I get undefined symbols, console
output reads:
  ld < vme49.munch
  Undefined symbol: devDisableInterruptLevelVME (binding 1 type 0)
  Undefined symbol: devConnectInterruptVME (binding 1 type 0)
  Undefined symbol: devEnableInterruptLevelVME (binding 1 type 0)
  Undefined symbol: devInterruptInUseVME (binding 1 type 0)
  ld error: Module contains undefined symbol(s) and may be unusable.
  value = 0 = 0x0
  Done executing startup script /home/jad/ppcBootDir/st.cmd
The libCom calls are in device support, my devAUX_CLK module, used by my
devERL_EMS module, used in my IOC vme49.
In the vme49 IOC src folder the Makefile looks like:
PROD_IOC_vxWorks = vme49
DBD += vme49.dbd
# vme44.dbd will be made up from these files:
vme49_DBD += base.dbd
# <name>_registerRecordDeviceDriver.cpp will be created from <name>.dbd
vme49_SRCS += vme49_registerRecordDeviceDriver.cpp
vme49_SRCS_DEFAULT += vme49Main.cpp
vme49_SRCS_vxWorks += -nil-
#The following adds support from base/src/vxWorks
vme49_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
#add a definition for each support application used by this application
vme49_LIBS_vxWorks += devERL_EMS
vme49_LIBS_vxWorks += devAUX_CLK
vme49_LIBS_vxWorks += asyn
vme49_LIBS_vxWorks += stream
vme49_LIBS += $(EPICS_BASE_IOC_LIBS)
Happy New Year and thanks,
John Dobbins
Lab for Elementary Particle Physics
Prev: Re: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Andrew Johnson
Next: PowerPMAC_EPICS Krzysztof Lazarski
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
