1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin?
To: [email protected]
Date: Mon, 5 Jan 2009 11:33:13 -0600
Hi Steve,
> On Saturday 06 December 2008 22:37:12
Wow, has this message really been waiting in the tech-talk queue that long?
Hopefully you've already found the solution, but I'm answering here for
completeness.
Steve Banks wrote:
> Has anyone else run into problems with the example app in EPICS Base
> 3.14.10 with Sequencer 2.0.12 when running on Cygwin (ARCH=cygwin-x86)?
> When I build the example application with the SNCSEQ in the RELEASE file
> commented out, the IOC builds fine and my trusty old EPICS console starts
> up with no problem.  When I rebuild the application with SNCSEQ=/epics/seq
> in the RELEASE file, it builds fine but when I run the IOC it goes
> immediately back to the bash command prompt, no errors, no EPICS console.
Does your PATH variable contain both the base/bin/cygwin-x86 and
sequencer/bin/cygwin-x86 directories where the DLLs are installed (note bin,
not the lib dirs)?  It is highly annoying that there is no message displayed
when a needed DLL cannot be not found and the binary just quits with no
message.  Of course this isn't the only reason this might be happening, but
it has hit me several times.
- Andrew
The best FOSS code is written to be read by other humans -- Harold Welte
RE: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Steve Banks
Prev: Re: How to implement simple control algorithm (one more question) Andrew Johnson
Next: adding libCom calls to vxWorks IOC John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <2009>  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: How to implement simple control algorithm (one more question) Jeff Hill
Next: RE: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Steve Banks
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
