1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: How to implement simple control algorithm (one more question)
To: "'Dalesio, Leo'" <[email protected]>, "'Ilya V. Kitaev'" <[email protected]>, "'Kalantari Babak'" <[email protected]>
Cc: [email protected]
Date: Tue, 6 Jan 2009 09:31:17 -0700
FWIW, if you change MAX_STRING_SIZE there are two CA related consequences to
consider.
1) You will create a new CA protocol that is incompatible with any CA
protocol with a different MAX_STRING_SIZE.
2) Padding overhead for sending small strings over this new CA protocol
increases.
BTW, I do see this MAX_STRING_SIZE limit, as an issue that needs to be
fixed.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Dalesio, Leo
> Sent: Sunday, December 28, 2008 8:03 AM
> To: Ilya V. Kitaev; Kalantari Babak
> YOu can make the strings as long as you like. You just can't set or get
> them through channel access then - a 40 character limit. I'm not sure that
> it handles this properly. Jeff or someone else should comment on that.
> Bob
> From: [email protected] on behalf of Ilya V. Kitaev
> Sent: Fri 12/5/2008 3:29 AM
> To: Kalantari Babak
> Subject: Re: How to implement simple control algorithm (one more question)
> Hi,
> Thank you for your answer.
> I'd like to ask one more question:
> Is it ok to break 40 chars limit in CALC field( or another text fields
> like DESC) ?
> I've changed this limit  to 200 in calcoutRecord.dbd, db_access.c and
> epicsTypes.h (MAX_STRING_SIZE define) and it works ok.
> 2008/12/3, Kalantari Babak <[email protected]>:
> > Hi,
> > You do not need to write your own CA application for that.
> > Monitor alarm status of your "ai" with a "calcout" record and write to
> > your "bo" upon occurrence of the conditions.
> > This can be done for example as the following:
> > record(calcout, "$(ALGORITHM)")
> >         field(INPA,"$(YOUR_AI_REC).STAT CP") # monitoring
> >         field(INPB,"$(YOUR_BO_REC).VAL NPP")
> >         field(CALC, "A=3?1:A=5?0:B")
> >         field(OOPT, "On Change")
> >         field(OUT,"$(YOUR_BO_REC) PP")
> > Alarm status value for HIHI is 3 and for LOLO is 5.
> > HTH,
> > Babak
Prev: Re: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Andrew Johnson
Next: RTYP field through the PV Gateway Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  <20092010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to implement simple control algorithm (one more question) Andrew Johnson
Next: Re: Problems with Base 3.14.10. and Sequencer 2.0.12 on Cygwin? Andrew Johnson
ANJ, 31 Jan 2014 · Home · News · About · Talk · Base · Modules · Extensions ·
